SpyderWolf
I honestly don't think the MAD does anything while you are stopped, or even driving slowly. When you are stopped, the Spyder is getting no real air flow through the radiator until it reaches 5 bars and the fan kicks on. At that point it is sucking in the air around the engine, and straight off the heated road surface so the cooling effect is minimal. Once you start moving again, cooler air gets forced through the radiator and the temp bars will eventually drop. Sometimes they drop a lot faster than other times, depending on traffic conditions and such.
As Lamont posted, 5 bars cannot really be considered hot for an engine anyway.
As for the heat on your leg and foot, much of that comes from sitting right behind the engine and exhaust pipes. However, I think it was Tom in NM who posted how to use some pipe insulation to block the gap where the hot air can be blown directly onto your foot. This may be another thing to look into for ryding comfort. Another helpful option may also be exhaust wraps.
As with anything your mileage will vary, but here is what I have noticed so far with the MAD installed at highway speeds. 70-89 degrees mine runs at 3 bars, 90-100 it runs at 4 bars. It has gotten close, but has not gone over 100 yet for a test here.
