micron exhaust
beerman
Just installed a new micron exhaust. Love the sound, it's perfect. Only problem was it was hitting the rear swing arm so you need to use a big spacer between the the clamp which goes around the can and the footrest bracket it to keep it away from the swing arm. You should also replace the exhaust gasket if you have many miles on the bike. I had 500 miles and was able to reuse it with no problems.
Glad you like it!
We recomend using the large black spacer that Micron gives with their clamp kit when installing it on a Spyder.
I hope you have many fun miles and smiles with your new system! :2thumbs:
MM
