My 2015 F3-S developed a "chirping" noise about two years ago @ about 35,000 miles. The sound usually occurs at 65-75 MPH. Sometimes it goes away when you change speed a little, but it usually returns. It sounds like it's coming from the drive belt area. I have adjusted the belt alignment and tension (set at 180 lbs) with no elimination of the sound. It had a BRP idler installed well before the noise started, but I have replaced the roller with Lamont's larger roller twice with no change. It has been making the sound both before and after the front sprocket recall & replacement was done - no change. I recently sprayed some belt dressing on it (both toothed side and flat side) which totally silenced it. I didn't like the idea of doing that and questioned what it would do to the belt long term, so I cleaned it and the and the chirping returned. It is the original belt and has about 42,000 miles.
Any help would be appreciated.
