Yeah, looking at your pics, Raprider, the Magic Mirror Mounts for the RT's as they currently exist
WILL NOT fit on an ST readily!! :gaah:
Even if it's possible to replace the Pins that I assume are on the other/male side of what you're showing us above, you'd hafta work out how the remove the broken bit & the two wire spring bits and replace them with steel plates so the magnets could hang onto them. :lecturef_smilie: On the RT's, each of those three female 'recievers' that grab the pins are a small removable/replaceable pellet so that it's a fairly simple matter to undo a few screws & screw back in a little shaped metal plate..... and that's not something that I can see being done quite so easily on that backing plate you're showing us - the receiver bits appear to be an integral & non-removable part of the whole plate!! :sour:
Just type 'Can Am Magic Mirror Mounts' into your browser's search bar & check out the images of the shaped plates, and those showing them fitted into the mirror.... it'll become instantly clear why the Magic Mirror Mounts as they exist right
NOW won't work for the ST's, but it doesn't really look to be
impossible to adapt the magnets (which are the pin replacements) to suit; so all you've gotta do then is get some appropriately shaped & secured metal plates into the right spots on the placcy plates your pics show! :dontknow: That should be
EEEAAAASY....... at least from here where I'm sitting back & watching all this unfold anyhow!
