Sorry, I have to ask. You say you now "encourage" the use of. Why ? What feedback? Has anyone actually had a mirror come off? I got your original tethers and didn't even bother with them. I've had them on bumpy roads and above "normal" highway speeds and they don't budge. I feel as if something happens to knock these off the mounting then the mirrors will probably be the least of my worry. So why are you encouraging the use now, what happened? BTW - I ABSOLUTELY LOVE THESE!
Doc Riverside has started a thread in the "General Discussion" Area about tethers for these mirror mounts.
His idea looks pretty neat! :thumbup:
As far as Russ changing his position regarding the necessity of tethers: :lecturef_smilie: Haven't YOU ever changed your mind about something?
Give him a break: he sees that there are folks with concerns, and is trying to react to it.
Maybe - if you have - THREE HANDS , it's easy to hold the mirror and un-plug the connector without the TETHER ....... However if you only nave TWO hands , the TETHER acts as the THIRD HAND ...... jmho ..... Mike :thumbup:Peter A or Russ, the question still remains though as to why Russ has now decided to encourage the use of tethers(Post 80). My reading is that it is simply because sooooooo many people are insisting on putting them on anyway, regardless of how secure the Magic Mirrors are, that Russ has "gone with the flow", even though he feels they are not necessary........but I could be wrong, of courseopcorn:.
Pete
Pete
........... As I recall , someone posted a " friend went over a RR track hit a pothole and the mirror came off " .... Russ then decided to re- recommend the safety lanyard thing ........ IMHO ( and His ) the mirror wasn't on correctly, and this was the CAUSE of the incident. ....Whatever , the Tether is no big deal .....the mirror is $ 250.00 + ........ BRP made no provisions for SAVING THE MIRROR AT ALL .......Why people are getting their Panties in a WAD over this is BEYOND my comprehension. If you read my POST # 61 above the fix is pretty simple, upon further consideration you don't even have to drill a new HOLE to attach the Tether in the upper plate..... just remove it then tie a big knot in the line you are using, ( so it won't pull past the edge ) put it behind the plate and screw it down........... jmho.......Mike :thumbup:Yeah, but was that RUSS'S reason, Mikey Boy?opcorn:
Pete
Polarity -- I noticed in Doc's video that he was careful to check polarity and indicated that the strong side needed to be away from the bike. This is confirmed in other threads where the analog gauges are sometimes affected. What I did to check, was have a weak magnet in one hand and the Magic in my other -- as I brought them closer together, the Magic either rejected, or was attracted to the other magnet and I made note of which side caused the attraction. This is the side I mounted facing out (or away from the bike) and towards the mirror. Did I pick the correct side to face the mirror?:hun:
I did a lot of research on magnets because I found my own for my mirrors ...... In everything I read I never saw any reference to a strength / pull difference between the poles of the magnet ...... and there are only TWO .....Every magnet has at least two identified as a North and a South ( they can have more tho )...... Either one will have the same pull strength against the same metal object as the other.......The test you described was a bit confusing , were you using magnets against magnets in this test ...... because if so a north side will push a north side magnet away from it .............. I hope this answers your understanding of magnets ............. Mike :thumbup:No feedback on my other question regarding polarity yet.
All the best .... Ann
So, now that you've fitted your Magics, does your temp gauge go immediately to half when you turn the ign on & then very quickly climb up into the red as the engine warms up? If not, then your installation is fine! :thumbup:
Dear Sir: I appreciate your Quoting me :clap:...... however you mis-construed it's meaning ..... The " getting their Panties in a Wad " was referring to the folks who - when faced with an OPTION .....are terrified of making a DECISION........ ie. don't you just love the posts that ask " what color Spyder should I buy " :banghead::banghead::banghead: ..... really , they are buying a $30,000 machine and are asking for other peoples opinions............. I hope this clears this up for you .... Mike :thumbup:Man I really hate it when people just can't be civil and have a normal discussion.
I asked a simple question, why the change in direction. Maybe a simple semantic thing but to me saying "we now ENCOURAGE" indicates there should be a REASON. If there have been cases of properly installed mirrors coming off, ok, fine, I agree with the use of the tether for everyone. But if its a case of they MAY come off if not properly installed then I think the approach should simply be - here is an optional tether if you desire to use it.
Bob's statement "As far as Russ changing his position regarding the necessity of tethers: :lecturef_smilie: Haven't YOU ever changed your mind about something? Give him a break: he sees that there are folks with concerns, and is trying to react to it." was defensive, argumentative and simply uncalled for. Nobody picked on Russ, I even said I loved them BUT if there is a concern I think I am allowed to ask what it is. Mike- nobody's panties are in a wad, only people that are getting crazy over a simple question.
Bottom line: These things are the bomb and my favorite add on - period, and would recommend them to anyone - tether or not. I'm in the camp of Peter A. and feel the tethers are totally unnecessary (AND THIS HAS BEEN STATED MULTIPLE TIMES IN MULTIPLE THREADS HENCE THE ASKING WHY APPARENT CHANGE IN DIRECTION). Like he said, my OEM mirror mount would actually wobble because the dealer couldn't even put the mirrors back on right. I'd have to fix the pins and redo them. OEM also never had a tether to hold in place as a third hand to disconnect wire. I don't feel I need that either. BUT - if someone wants a tether for whatever reason - god bless them, go for it, whatever gives them warm fuzzies. BUT - if someone is going to say they should be there or are encouraged, we should know WHY, simple as that.
Russ - keep up the great work - I know it's almost impossible to please everyone and I'm sure if something is discovered that actually warrants the use of tether in properly installed mount you'll let us know otherwise I'll assume they are indeed optional if someone wants an extra level of comfort.
