Low Speed / RPM Miss?
elkk
Friends 2008 RS SE5 has a low speed / rpm miss (up to 3500 rpm) then it clears up and runs fine. We are thinking coil pack, spark plug or wires. Any other thoughts? Are the spark plugs and coil packs hard to get to? Thanks.
Miss
Is the miss, off idle all the way up to 3500? If so, I would change plugs and wires. If it's just at 3500 ish, check y pipe gaskets and clamps.
Left side spark plug is easy, right side is harder, air box is in the way. Coil is easy access on left side.
It's may be the MAPS sensor, when it failed it did the same thing. Hard to keep running at idle, Hard time pulling out and would run fine after 3,700 rpms. The tech found it using there computer with the BRP software.
Mike
Thanks everyone. It seems to idle fine, misses just off idle to around 3500 rpm. Will check the things mentioned.
