Rattlebars
There is no actual throttle cable,you rotate a handgrip that has switch kinda like a light dimmer and that sends a signal to the computer to open the actual throttle butterflys by using a motor that rotates the butterflys.This unit simply takes that signal and modifys it to send a little more opening power to that motor on the butterflys.Ive always felt that the spyders required a lot of hand twist to get to full throttle but Im not that concerned that I would buy this.
That would be the TPS or Throttle Position Sensor. I have my commander attached to the brake MC with a zip tie. I'm a minimalist and don't like a bunch of stuff on my bars. Besides, under the service cover it's out of the weather and instructions say only change settings at a full stop. On my Note 9 fone, the app works great. It tells you what your setting is and has all the same buttons including the on/off button. Jury is still out on this though.
Does anyone know how to add a little more free play? I just want a smidge. I will pull my throttle apart and see if there's a way...
