How is the belt vibration? Wondering if that might have something to do with it. When I first got my 17' Daytona the belt vibration was terrible. In the same month I purchased the byke, BRP came out with their idler kit. I put that on and it immediately helped a great deal. As most of the members know, we then created our Vibration Damper and I started testing it on the Daytona. That now is a little over 10k miles ago, (9k on our unit and 1k on BRP's) and I have yet to see the reddish coating around the front sprocket. And if it is a lb to torque issue that is causing this then it should have happened to me. I occasionally will spin my rear tire, drift occasionally, and I am not a little person. Those of you that know me will also agree that is so. So, if is not a torque issue, then could it be a vibration issue?
Interested to know if you were running a vibration damper either the first time or now and at what tension you were keeping the belt at?
When I replaced my rear tire (spinning a bit) at 9k I reduced my belt tension to about 90 lbs off the ground. This gives me about 160 lbs with the wheel on the ground.
Hope you figure out what is going on.
Bottom line is that if we find it is vibration causing this we are going to be selling a lot of the Vibration Dampers........
