jmcbow
:dontknow: Recently installed the Corbin saddle seat & back rest. Big improvement over the stock seat (in my opinion). But noticed very quickly that the back rest itself is loose, it woobles from side to side. Took the back plate off (mistake, was a pain getting screws lined up again because the screws go thru the foam in the back rest) and didn't see any adjustments to eliminate said play in the backrest.
E-mailed Corbin to ask if this was normal, never got a response. The square post is tight and secure to the front saddle, the back rest is also attached securely to the square post except for the side to side play.
Any suggestions or info on this issue would be helpful.
Thanks
Thanks
