2011 RTL , ultimate goal of the project is changing the shift shaft. Need to remove the right footrest plate to remove shaft.
Has anyone removed the footrest support plate from the right side and reinstalled it. What are the steps for that?
The shop manual has no information on removing this. There is a section about adjusting the brake rod which requires removing the master cylinder and it will be a cold day in Hades before I remove a functioning master cylinder.
TIA
TIA
