looking for recent opinions on cat-delete pipe.. 2020 f3 limited
fredgal
ive read all the older post's on this subject, i ordered a cat delete pipe for my 2020 F3-limited, im thinking baffle in, with end cap out ? .. is this the mid-level sound improvement.. its just too quiet when i get on it. im a guy that shifts at 3000-3500 rpm's in each gear,, sometimes 4000 rpm's. thanks for input.. this is the last mod for my machine this yr...:banghead:
You did not specify which cat delete. i have the RLS with resonator and stock muffler. Nice, smooth, throaty sound. Only a little louder than stock. Ricky told me what it would sound like before I purchased. He was spot on and I like it.
I went with Lamonster cat delete pipe with the baffle and an Akrapovic Sinister Silencer. Great sound and I love the decel burble.
I don't really think the engine &/or exhaust system has changed significantly since 2014 when the 1330 triple came out; so really, all those older threads & the posts they contain with opinions on the cat deletes for the 1330's are going to be just as valid now as they were whenever they were posted! ;)
Whatever way you go, there's no real denying that the OE exhaust is juuust a bit anemic sounding, and pretty much anything that'll free up the exhaust flow & lessen the baffling a little is likely to make it sound at least a bit more like an engine instead of a run-away sewing machine! So aiming for a mid-level sound improvement by installing a cat delete & just the one baffle's gotta be a good start! :ohyea: . Go for it! :thumbup:
thanks for your replies, i purchased one from baldwin-iron-works, it was less than 200.00 so i thought is give it a try,, i guess ill leave the baffle in with plug out,,
i want alittle more sound
That's what I had. You'll like it.
That is the one that I bought. I left the baffle out all together. It gives it more throttle response, but it is a little loud (stock muffler). I wanted to try it with the baffle in, and plug out. But I was afraid that if I wanted to take the baffle out, it would not be easy to remove after going through a few heating cycles. I will live with the noise for now, as I plan on getting the ecu tune and will need that extra flow.
so after you run it awhile with the baffle in. it might not come out ?? so i guess i should try it without baffle, and if it is too loud, put baffle in,, guess ill do that first.. i have 2 friends that are going from 2 wheels to 3 wheels next yr. they love my spyder,,,,,,
I have the Lamonster style cat delete with the screen type baffle. Improved that sewing machine or vacuum cleaner sound just a little. As far as HP increase, I really don't know, but I doubt it. The ECU controls everything on our scooters so any HP improvements I believe is just wishful thinking. If you want to really increase HP go with an ECU flash or install a hellcat hemi.
im not looking for HP gain . the bike needs more sound.. so baffle in, baffle out,,, baffle in with plug,baffle without plug. guess ill look for some sound clips
Remember you've got a high wind'n three banger. Baffle in or out is not going to make a large change in sound. You have to change the muffler to get a bigger change in sound. There isn't anything around that will duplicate the sound of an HD EVO. I ran a 2Bros straight-through muffler (if you could call it that) for a while and finally took it off. It was so God-awful loud that it would wake the dead. It did have that Harley blip sound when I shifted, but the rest of the time it sounded terrible, to me at least. Together the OEM cat and muffler are hot and heavy and I can't begrudge anyone for wanting to lighten up and cool down some. Good luck in your search.
With the baffle removed, the Baldwin cat delete is quite a bit louder than with the baffle in. Baffle + end plug isn't much louder than the with the cat installed. I currently am running the TBR exhaust. Yup, it is loud, even with the TBR P1X suppressor installed. That said, I did slip a baffle inside the TBR delete pipe. Along with either a PX or PX1 suppressor, the sound is awesome.
well i want it louder, so baffle with plug is off the list.. thanks, guess im going to go with no baffle, and if i want alittle less noise , then i will go with baffle in- no plug,, thanks... pipe is suppose to be here today.. wish i had the pipe today, as im off work today, and every monday from now on........
Now, my statement is not scientific. It is just a guess. My thoughts are that once the pipe goes through a few heat cycles, it will be a lot harder to remove the internal baffle, without possibly destroying the pipe or having to use a lot of heat and possibly some sort of chisel or puller. The pipe with no baffle is a little too loud to hear my tunes. when riding.
You could be right on that, but I'm not sure. I believe I'd destroy the baffle if I wanted to remove it as opposed to damaging the pipe. I may know more about that after I remove my baffle when I upgrade my ECU.
I R&R'd my baffle a couple times. Spray inside with WD40/similar, tap a few times with rubber mallet and pull the baffle out with the included spring puller that Baldwin supplies. Easy...
Well, lemme tell ya. I went through all that changing pipes for better sound on a Harley I once owned. At 67 I'm all grown up now and ain't changin the exhaust on my 2015 F3 just for louder/deeper sound. I want quiet. Enjoy your bike.
yea im 63 lol , coming from a 1500 vulcan with cobra exhaust it was loud, i just want alittle more sound, from my spyder, not alot,,
