cruisinTX
final chapter
Just about have all the additional lighting complete now. I purchased these 12" red strips at the same time I got the amber ones for the front turn signals. I finally got motivated enough to get the rear panels out of the way to add them today They will definitely add a bit better lighting from the rear AND from the side with one LED strip on each side. These have a 120° beam angle and when mounted on the proper angled portion of the rear fender, they are visible from the side and the rear. Oznium builds these with marks on them so you can cut to lengths you need without ruining the entire strip. I needed 9" on these so the last three got cut off and are mounted at the bottom outside of each saddle bag to serve as additional turn signals. The 9" strips are wired into the license plate circuit.
Thanks again for all the input and the advice to check out Oznium!!!!
