LH indicator not self cancelling
Ross
Has anyone adjusted the self cancelling feature on a 2012 RT-S SE5. If the corner is more than 90 degrees it will cancel, whereas the RH side cancels normally. We ride on the LHS of road over here so the LH turns are usually sharper than RH. Any suggestions most welcome.
Ross
If the switch sticks to the left, as many do, it will not cancel. If the switch is centering itself, the steering angle sensor should be zeroed with BUDS.
