ulflyer
OK. I talked directly with the tech and the service manager at the dealer where this controversy started. The information the tech now has from BRP is the same as in Lamont’s post – 4.7 liters SE, 4.9 liters SE plus HCM filter, 4.5 liters SM. He said that when you fill it with those quantities, then ride it and check it hot, his experience so far shows a dipstick reading just above minimum. There is no reduction beyond those stated numbers.
The confusion about whether this is a reduction or not comes from other info where BRP said to put 5.6 liters in an SE for a full change. The info in the owner’s manual (from the BRP website) shows the following (pasted directly from the owner’s manual):
SM6 Model
12. Pour 4.9 L (5.2 qt (U.S. liq.)) of the
recommended oil into the engine.
SE6 Model
13. Pour 5.3 L (5.6 qt (U.S. liq.)) of the
NOTE: For SE6 model, when the the
HCM oil filter is also replaced, the
total oil quantity to add will be 5.6 L
(5.9 qt (U.S. liq.)).
The reduction from 5.6 liters full-blown SE oil change to 4.9 liters is a reduction of about 0.7 quarts. The info the tech got from BRP said that this extra 0.7 quarts could cause a reduction in power, as Lamont indicated. The key as the tech said is 1) use the numbers Lamont posted, 2) check it hot after a ride, and 3) keep it above the minimum.
Still seems to leave unanswered questions such as will they change the owner’s manual, and is there a change in the allowable range? If 4.9 liters is optimum and what you fill it with, how low can you go as oil is consumed? Are you flirting with too low and must be extra vigilant about keeping it above the minimum?
Hope this provided some clarification.
I changed mine today with Motul 7100 which came in Liter bottles and put in exactly 5 Liters rather than trying to measure out some small amount . After running it, the oil level is exactly on the middle bulb of the stick. Previously I had used 5.6 qts which put it at the top of the stick.
Correction: After a longer run today it checked out about 3/16th inch above the center bulb on the stick, rather than right on the bulb
as I previously reported.
