Kury ISO grips
Genet
This is for the guys that have installed these grips on a 2013 ST S.
i just got the 6383 (black ) grips today,I'm ok with what needs to be done to get them on,I'm confused about the screws at the end of the stock grips.do they get used after the end caps are taken off? In the videos I have watched and the photos from Lamont's post , I didn't see or hear any mention of them.
can anyone help ?
Gene T
I think you want to use the screws.
I think I read that you need to put the scepter backing on the throttle grip to keep the spring in place. It would probably be a good idea to put the screw in place on the other side as well. The Kury grips use different screws for their end caps, so you won't be hurting anything.
hope this helps.
hope this helps.
Excellent,thank you so much.
