IWN2RYD
Weeeeeeeeeeeeeeeeeeeeeeeeeeeeell... I must say this with a word of caution. But this was NOT an easy install.
If you watch the video, the first clue will be the fact that they all ready have the frame mount installed and bolted in "Before" Matt demonstrates the install.
opcorn:
Do not get me wrong. As long as you are level headed and have a general set of tools the install will happen. :2thumbs:
I do not know if the tolerances are so close together deliberately or not. Or if BRP has allowed for a few extra wide QC items in their allowed tolerance levels... But I have to hammer the crap out of mine to get it in (Rubber blunt hammer). I mean the back side of it, not in anyway bending or modifying it.
And I had to do it twice :roflblack:... sigh...
The first time I tried it looked like it was at to much of an upward angle to install with the tail lights installed.. So I took those off. Hammered it in... And then went :cus::cus::cus::cus::cus::cus::cus::cus::cus:. My eyes told me I failed. I never should have removed the tail lights because I will never get the back bolts back in place.
So I tried a few tricks to get it back out... NOT... Ended up taking one of my "Tree stump remover" cables... Sliding a bolt through the mount with a bunch of washers to slip the cable through... Attached the other end to my tow hitch on the truck.. And tried a little pressure with the bike powered... Nope... Then tried a little love with more power... Nope... Tried a little more power with slack at first... Came right out...
Back to the garage for round 2...
Had to do a little finessing and a lot of rubber hammer, maybe even a little body English and all was good.
One thing is for sure. If we ever sell the bike. It is staying right where it is.
Now I want to mention one VERY important item here.
If you EVER plan to change the taillights... Do yourself a favor and do it before you install this kit. Because if they deliberately designed this to be that tight where we have no choice but to hammer it in... You will have a very troublesome time down the road to get this off again. Can it be done? Yes sure. But not without leverage and time.
Also wanted to mention how beautiful this unit is. They did another top notch design for sure. Only complaint I have cosmetically is the top plate looks to have been chipped before they shipped it. The padding they used was also top notch... The box showed up in perfect shape with no puncture marks or anything from transit. The very end has no powder coat (Not the end I was hammering, the top plate we bolt on) so I will need to seal this before it gets wet...
