IS This OIL ok
nasty
Hi,
Been looking on forum for oil for my rt 998, Valvoline is a bit difficult to get over hear in England.
so I have found this Castrol Power 1 Racing 4t 10 40 fully synthetic.
With the following specs.
Specifications
  • API SJ
  • JASO MA2
Look forward to your replies. Cause you out there are very knowledgeable about the spyder and its querks
Hi,
  • API SJ
  • JASO MA2
Yes it will work jaso ma2
That will work just fine.
It is a oil designed for a motorcycle.
It does not have an API rating of SM.
It is 10W40 close enough to spec of 5W40.
Not a required spec but as a bonus has a JASO clutch slip rating of MA2
OIL
Hi,
Specifications
  • API SJ
  • JASO MA2
Frankly, imho, that's better than anything you can get from BRP, and far exceeds the Spyder's oil spec's....................Mike :thumbup:
JASO MA1 and JASO MA2 both cover different parameters for the wet clutch.
Plain JASO MA without a number after covers the same parameters as both 1 and 2 combined, plus more.
I only use JASO MA without a number as that's what's recommended by the makers.
Just had this debate with my Penrite stockists.
JASO MA approved Penrite 5-40 MC full Synthetic is what I use.
