SPYDERJERRY1
Has anyone ever used Ultra1Plus oil ? I have a 2020 Spyder RT Limited. This oil has the correct specifications for our machines....5W40 Full Synthetic 4T API SN JASO MA2. What do you think?
I think if it meets the specifications then go for it. You are going to get all kinds of answers from all kinds of owners which is fine, but my choices are always "does it meet the specs" for my equipment.
I am guessing this oil is about $15.00/qt. I know nothing about this oil but the specs you published seem to match what we need so if it matches your price point go for it. Have you used it before? What on? Can you get it if you are out on the road or do you have to carry some with you? Personally I am in the under $10..00/qt group so I stick with Shell Rotella T6, Valvolene T4, Castrol T4. Not saying they are better then your oil,they just fit my price point and I can find them almost anywhere. But I also change oil every 4500 miles , so I also don't worry about myoil breaking down over a long intervale. I change oil twice and sometimes 3 times a year. Lots of happy miles with your new ride.
:agree: , also with Navydad ..... I read somewhere there are only 7 or so OIL refineries in USA. .... however there are probably 50 Brands of oil .... some charge more , some charge waaaaaaaay more for the same Oil ..... good luck .... Mike :thumbup:
Wow, another oil thread. We'll all be dead and gone and they'll still be discussing oil even though most transportation will likely be EV's. My (limited) study on oil boils down to confirming BK's comment and that oil is sold by the train carload over the table to the highest bidder. That's the fact of it. Then it's shipped off and rebranded by the purchaser who adds to it, or not, and advertizes their oil to be the best on the market. It's a giant shell game. What I appreciate is that my 1330 does not use oil. And, I can run the same oil for 10k miles and it still meets usable specs. How great is that? 5 qts for 10k! Do the math and by all means, use the recommended oil specs for our machines and enjoy the ride with whatever brand of oil you use.
:agree: Now, what about those tires?
Your Spyder requires an API SL rating. This rating is for engines made before 2004. The SN & SM API rating supersede the SL rating. See - API SN/SM/SL/CF. However, while the SN & SM rating exceed the SL ratings for wear, friction etc. The ratings apply to the engine. My concern is many of the SN & SM oils achieve better wear protection and are longer lasting, or provide better mileage due to additives that improve (lower) friction. Your Spyder uses the engine's oil to lubricate its wet clutch system. I noticed that for my last oil change I went with Amsoil full synthetic 05w40. When starting up cold and putting in gear the clutch would slightly slip then lurch when I applied the throttle. Within one or two minutes of operation this tendency would go away. I have N RTL S2S thus the semi-automatic. I can envision those with a manual could run into clutch slippage, and thus premature wear, if they frequently rev it up and dump the clutch, i.e. burn outs, while using Amsoil. I am a long time Amsoil fan but for my Spyder I will be trying other more modern oils than BRP's 2004 standard. Longer lasting, better wear protection and better mileage benefits of the newer oils is desired, if and only if, they do not have a potential adverse impact on the clutch.
Available at Amazon, 7.48 a quart.
Recent player in the market, joined the PQIA in 2021.
It may meet the specs, but they did NOT apply and be certified for JASO MA because it's not on the list.
(Rotella isn't either).
For 6.67 a quart, I'd move over to the 5 quart Kawasaki 10w40 package that is JASO certified.
https://www.amazon.com/Kawasaki-999...efix=kawasaki+motor+oil,automotive,850&sr=1-2
Here is the JASO list if interested.
https://www.jalos.or.jp/onfile/pdf/4T_EV_LIST.pdf
The Kawasaki oil you link to is a synthetic blend. Similar to the XPS BRP 05/40. It is designed for lawn mower engines. The information I can find lists it as JASO MA rated. That's a long way from the JASO MA2 rating needed in our Spyders. Though the JASO rating list provided does show some MA2 rated 10/40 Kawasaki lubricants. I don't find a direct reference to this oil there.
I will go out on a limb and say that the op has made a decision and moved on as this was asked in April of 2022.
