Is the Alternator shaft squeal just a nuisance, or is it damaging anything?
I wonder if BRP is simply going back to the original parts that did not have this problem. Seems like the easiest, tried and true solution.
From what we can read in the bulletin, they are not changing the whole shaft but rather changing the “alternator shaft friction washers”
OK, so here's an update after the TST was performed on my Spyder
Short story : The fix didn't work on my 2024 S2S ☹️
Long story : Got it back from the dealer on Friday (April 17) after they changed the "Friction washers" and I had the chance to talk with the mechanic and I was shown the used pieces - they were worn out !! (the 2 parts identified as #7 in the drawing in post #7 of this thread),
Anyway, brought it back home, got to start it twice on the Friday and all was good. The next day, it started without the noise and drove it for about 90 miles (150 km) and after lunch, the noise came back upon starting, just a little bit for 2-3 seconds. Stopped for gaz a few moments later, and when I started it back, the noise was there in full blown energy like before... after only about 5 starts and 90 miles!! Now every time I start it, especially when hot, it's whining again just like before the fix!
Stopped by the dealer today (Wednesday April 22) and let them know, they will reach out to BRP to see what can be done from there.
So after a few exchanges between the dealer and the BRP engineering team, and some BRP investigations into the internal data from the Spyder, they have ordered the dealer to go ahead with a whole "alternator shaft assembly" replacement which will be performed next week. Looks like I have the only Spyder which has had the TST performed on it that is still making the noise... Will keep you posted.
After the washers are replaced, I wonder how long before the squeal comes back?
In my case it was the next day it came out of repair with 5 engine starts and a long drive which at the lunch pause after 90 miles the squeal came back in full blown ☹️
I can assure you that yours is not the only update 'Fail'. I am hoping for the best, but I have to say I am skeptical that a shaft replacement will improve things. I am happy that BRP is going the distance with assistance in the matter. And with the rest of our Spyderlovers community, appreciate your detailed updates.
I assume that they have load tested the battery and found it in good condition.
Correct, I was in the dealer 2 times for different testings with and without load and data extracted from BUDS system that was sent out to the BRP team. The battery is a new one since last summer (not the cheap OEM one from Haijiu with only 300 CCA that I was provided with). The first shaft assembly (original part) lasted 10 000 miles and it took 9 months to get a fix that lasted 24 hours and 90 miles on mine. At this point, I'm willing to try anything to fix it !! On a positive note, I am glad how serious they are about finding a solution and how I am being taken in charge both locally by my dealer (Lapointe Sports) and the BRP HQ support team.
Another day, another update on my (too) long lasting issue
Monday this week (May 25), the whole alternator shaft assembly was changed, picked up my Spyder at end of day and all was fine... temporarily!!
Brought it home, took it out for a ride yesterday (Wednesday) and sure enough, it didn't take long for the squeal noise to come back, roughly after 3 starts of the engine and about 40 miles ☹️
Stopped by the dealer on my way back home, who gives me great service no matter the results, and showed them the issue (again). They will exchange with BRP engineers to see where to go from there.🤞
Keep your chin up and keep paddling, because if you stop, they will stop and you will drown! Good luck, I don't think you're the only one out there, there's more!!!
Have you tried Amsoil?
No I did not, would you think it could be a solution?
Spyder is still under the first 2 years of OEM warranty, trying to let BRP propose me a solution... hopefully?!
Thanks, I am as I can still ride the machine as per BRP, other than being an annoying noise, I'm good all of this.
Output shaft components on the 1330 alternator run in oil. Parts 1-12 and 17-18 are lubricated with engine oil. This includes gears, bearings, washers, etc. All are potential points of friction which will generate noise if components are defective or lubrication is not adequate.
As you can see, the alternator is mounted high on the gearbox assembly. Maybe there isn't sufficient lubrication with those units that are squealing.
but why wasn't this a problem with earlier 1330s?
It's just that an Amsoil solution would be the quickest, easiest, and cheapest option. It has worked (as far as I know) for almost everyone who has tried it.
Still, I agree that a hardware fix would be excellent. But it sounds like BRP may be nearing the end of their rope in that direction.
An excellent question. Obviously, something has changed. You would think BRP could put their finger on it quickly, and they may have (internally). But that does not necessarily mean the fix is simple. Sometimes it's more difficult to go back than it is to go forward.
An excellent question. Obviously, something has changed. You would think BRP could put their finger on it quickly, and they may have (internally). But that does not necessairly mean the fix is simple. Sometimes it's more difficult to go back than it is to go forward.
Thanks for you input, will keep updating the situation
So I recently did the Aimsoil. It worked great for about 400 miles and its back. Not loud, but there and I'll be damned if I am going to take it to the stealer and they keep it for months to do the so called repair. They had my bike for 30 days after I bought it and had to take it back for a dash issue after having it for a couple weeks. Till I see and or read that BRP comes up with a true solution that actually fixes it, I'm going to enjoy my driving season.
Solved mine. I was skeptical but within a few hours riding time on the new oil, the noise is gone. I have put approx 2500 miles on the bike since.
It is frustrating that the Amsoil solution works most of the time (as far as I can tell), but not always. One user said it helped with the 1st oil change, and completely resolved the issue with the 2nd oil change. That doesn't make sense to me really. But a fix is a fix. Even if you're not sure why.
