Flamewinger
Unless you remove the headlamp housing, it's a struggle.
Remove speedo/tach. Reach in and remove boot, spring clip then bulb. Finding someone with small hands would help.
The new bulbs come with a cable and has heat sink ribbons and make for a difficult install. I unplugged most of cable. There is one part that you unscrew lock ring. Fit bulb down into socket and work spring clip over back of bulb and clip. I used hemostats to grab seat sink ribbon and push boot over 'stats and ribbon. Then worked cable through boot. Wrapped boot around outside of socket.
Plugged everything together and tie-wrapped cables so they don't shake around.
Opened heat sink ribbon
Cable connection on back of bulb that the spring clip has to be forced over.
