ARCTIC
I bought the HID lighting kit from Xenon Depot. Spent an insane amount of time getting the spyder tore down and carefully routing wires and securing all wires from harms way. Tested the lights and they fire up with the trigger switch on the right handlebar PERFECT... Tried starting the spyder and it fires for 5 seconds then kills the motor and the display says " VSS fault" and "check DPS". I cannot get the spyder to run with the headlights connected. If I pull the fuse it will start and most times have a very high idle and other times run just fine. :dontknow::dontknow::dontknow: If it pull the fuse for the headlights and start it and then push the fuse in while it's running.... sometimes it revs the engine up and won't idle back down and other times it kills the engine instantly. Anybody got any ideas???? Frustrated doesn't even begin to describe my HID venture :banghead:
