Idle fluctuates between 900-800?
Yup! :thumbup:
It should ultimately settle in at just about 900 rpm once it's nicely broken-in.
Do you have it in gear with the clutch pulled in when you're seeing these rev levels? It could be affected by a bit of clutch-drag.
Always check the idle rpm in neutral.
Relax..!!
it will settle down. You will always have a bit. Check back when you have 3,000 miles...:roflblack:
Most tachs seem to fluctuate + or - 100 or so. They do seem to settle down after a couple thousand miles. Waiting for a light yesterday, I noted mine was rock solid on 900 rpm. (2014 model).
Thank you all.
Checked at neutral. Keeping revs 3.5-5k for the first 600 miles, then increase from there. So far my tight turns needs work. This will take time.
