2018 F3T will not downshift automatically - any ideas?
gjordon
My wife’s 2018 F3T has decided to stop automatically downshifting. When starting cold it may downshift a couple of times but when it does work, it seems to downshift at the wrong RPM and will lunge pretty hard at the shift. Once it warms up, it will not downshift at all. You can come up to a stop in 6th gear if you don’t watch it. It will manually downshift as its supposed to.
I’ve also noticed sitting at a light you have to apply the brake pretty hard to stay stopped because it wants to go. The idle RPM has not changed since this started and stays at 800-900. It has also died a couple times at a stop but does start right back up.
When upshifting and running at highway speeds all seems normal.
There are no fault codes.
I know it most likely needs to visit the dealer but the closest dealer is 3 hours away and I haven’t been too impressed with their service so far.
I did replace the LH multifunction assembly a few months back for no reverse or manual downshift which resolved those issues.
I haven’t been able to find much of anything on this issue and hoping someone may have a suggestion.
You have a HCM failure of some sort. The TCM controls the HCM line pressure which control the clutch engagement points. They are obviously incorrect.
Because you are so far from a trusted dealer I would first try a complete oil, engine filter and HCM filter change. I would use the BRP 5W40 oil to establish a baseline. I recommend BajaRon for the filters to ensure you get the correct and complete kits.
After changing the oil and filters drive for at least 100 (200 better) highway miles if you can do so safely. You want to circulate the oil through the filters and through the clutch plates (they have cooling ports) therefore every few miles or so cycle through the gears 6-5-4-3-4-5-6 at least times.
If the symptoms mostly improve repeat the oil and filters change and thank your lucky stars.
If they don't you may have CANBUS problems, TCM firmware problems, TCM short/long term trim problems, dirty or worn HCM solenoids, or failing/disconnected HCM temperature and pressure sensors.
Hopefully someone can provide a better and cheaper diagnosis than mine.
Best wishes.
Thanks for the reply and the suggestions.
It has right at 22k on it now and close enough for its next oil change. I didn’t have any idea about the transmission filter so I’ll take care of that as well.
Anything outside of that I guess I’ll be finding a dealer.
This is strictly from memory and I can't find the video. Possible obstruction under a solenoid valve seat and BUDS was used to fully open the solenoid and flush it out. Don't remember if it threw a code but they used BUDS to check the pressure points in the system and found the problem.
.... I’ve also noticed sitting at a light you have to apply the brake pretty hard to stay stopped because it wants to go. The idle RPM has not changed since this started and stays at 800-900. It has also died a couple times at a stop but does start right back up....
I had that exact problem. Posted about it last year. The clutch basket central nut came loose over time. Dealer took it apart and fixed it in one day. It's been perfect ever since.
https://www.spyderlovers.com/forums/showthread.php?150902-1330-SE6-Clutch-engagement-at-idle-problem
That sounds just like the issue and makes sense but you didn’t mention any issues with the auto downshift. I guess I could have two unrelated issues other than they both started at the same time.
I guess it’s time to find a reputable dealer who accepts my warranty.
Thanks for the tip!
Did you ever resolve this problem. I just bought a 2018 F3 that is having clutch issues. Have to push the brake pretty hard to sit still, foot off the brake it drive away at idle up to 20 to 30 km/h. Shifts poorly and won't downshift all the time.
Immediately change engine/transmission oil, engine filter and HCM filter. Contact BajaRon (a sponsor) for details and parts. Do not drive any further until you do this. You are at risk for damaging the clutch plates.
You didn't say your F3 was an SE6 or SM6. You need to work on providing more information. Simple stuff like mileage. It's not that hard.
Assuming you have an SE6, it uses hydraulic pressure (about twice engine oil pressure) to engage the clutch. Something in the HCM is causing it to increase that pressure too early or is not allowing to be released (the HCM uses variable pressure control to provide a smooth engagement and shifting experience - the Bosch TCM is almost as complicated as the ECM).
After you have changed the oil and filters, if you are having the same symptoms you need to have your F3 diagnosed with BUDS.
