Snowbelt Spyder
Well-known member
Try looking at this. They call this the blow-by connector. There's a vent tube attached to it. You can remove the vent tube and check things out. There's that o-ring shown, and also what they call a v-ring that requires valve cover removal to inspect. Not a simple job. The question though, would be what is causing the excessive blow-by in the first place, right. Sorry I didn't see that the first time. The other internal vents are venting the oil tank. They don't appear to have suction on them. If you're still interested in trying some magic juice, you might try Yamalube Ring Free. Works on boats and BMW bikes. Maybe make the first dose a double, and do an Italian Tune-up.
PS. Did the previous owner use ECO Mode a lot?
