i really need so advice
Questions
I got a 2008 spyder and I'm not getting spark on the back cyclender I put new plugs wires and coil and still nothing I checked the code it was p0352 I don't know what else to try and I hate to bring it to a dealer cause its expensive any ideas please
Are you getting power to the coil?
ECM Module
Blown fuse, damaged circuit wires, damaged connector, damaged or disconnected ignition coil.
Check fuse F8, check connector HIC that connects to engine harness to the vehicle harness, measure resistance from harness connector: 5-ECM-A1 to 5-COIL-1 (Expected value: < 2 ohms), measure voltage between harness connector 5-COIL-2 and ground. (Expected value: 11 to 13 volts).
The wire that plugs into the coil were dose that run to and is there another plug on the other end or is is wired into the fuse box or computer
P0352 - ECM - Ignition coil stage 2 short to 12V or ground.
Cause - Blown fuse, damaged circuit wire, damaged connector, damaged or disconnected ignition coil. Test as Docdoru described above.
