The continuing saga:
Yesterday I set out to find the clevis. Since I live on what people say is the largest pleasure boat harbor in the world and sail boats use many clevises, I headed out to our local West Marine store to look at their selection of same. Not so! They had a good selection of clevis pins but no clevises. A salesman explained that people drop clevis pins overboard but seldom lose a clevis so West carries replacement pins only.
At this point I began to think that Nexus was very fortunate to find a clevis he could use, at a local hardware store. I figured I could end up wasting the day trying to find a store that catered to boat builders instead of boat users and then maybe not find one the right size. So I decided to head to my shop and machine my own clevis. However, I did buy a clevis pin and a little bag of stainless cotter pins at West before leaving the store. I would need a longer pin to replace the one on the Spyder when I added my clevis to the stack. I purchased a 5/16" x 1" pin which turned out to be just the right length.
Back at the shop I started looking at my assortment of metal odds and ends. I didn't want to use steel because I would have to get it plated or powder coated to prevent rusting - more hassle. So, it had to be either aluminum, brass or stainless. Aluminum would wear fast, stainless would wear well but be a slow machining process, I decided brass was a good compromise between those.
Before starting this, I went over to the hose company (Mesa Hose) and had them make me up the hydraulic hose, since it was Friday and they are not open weekends. I also purcased from them a flare fitting, like to one that came on the cylinder, but a right angle one. That would shorten my hose length requirement by letting the hose come straight up from the end of the cylinder. I had them make a 60" hose while I waited. I chose the type that has a protective plastic sleeve over the metal braid so I wouldn't have to worry about abraiding on parts of the bike.
Back to the clevis project: I could have used round bar stock but I just happened to have a piece of 1" hexagonal brass bar stock. That works well because it can be chucked in a lathe's three jaw chuck for drilling the shaft hole and still has flat sides for aligning in a mill vise for cutting the 5/8" wide slot, and drilling the pin hole, that makes it a clevis.
The clevis turned out great but by the time I had mounted it on the Spyder brake pedal, it was time to put everything back together so I could ride back home from my shop (~ 3 miles). Having to have the Spyder in riding shape every day definitely slows up this project.
Today the job will be to fabricate the right angle bracket that will mount the slave cylinder to the foot rest bracket. Instead of using steel, as Nexus did, I will use aluminum but of course thicker than his bracket was, in order to make up for the reduction in strength of the metal used. I sure don't want this bracket bending under load!
Stay tuned.............................
opcorn:
