mounted the assembly to the table, perfect fit to the bike. turns out the ramps are a little to long to fold backwards, need to trim off a couple inches. the pipe started to bow when i lifted the table, so i'll add clamps in the center as dannymax advised and see how it does.
on a side note, the bike would not start to get it off the lift. found a slightly loose ground cable. cleaned and tightened and put the tender back on it. i'll check it tomorrow. could be time for a new battery. TBC.......
Check battery voltage. If low, charge the battery then remove the charger. In a few hours to overnight, check the battery voltage. If less than 12.7, the battery is not holding a charge or you have a parasitic loss. If 12.7 or above, it should start the Spyder. If not, and the terminals are clean and tight, check the rear frame grond for tightness (negative jumper terminal under the seat) and check the positive jumper terminal (starter relay) for tightness or a loose post. If all seems well, hold the throttle wide open to prevent starting, and watch the voltage as you crank the starter. It should remain above 10.0 volts. If any of the voltage tests fail, replace the battery.i tried a 1/2 nipple and it would not go. the o.d. looked closer to 7/8 than 3/4, so i put on the center clamps and gussets. it feels rock solid. bike wouldn't start , to test out the lift. same as sunday. cleaned and tightened the ground cable. checked voltage with a meter, showed 12.9. put tender back on and bike started mon. morning. went to start it this afternoon to test the lift, and would not start. ur thoughts?opcorn:
new battery should be here in a few days, that should take care of it:thumbup: Merry Christmas to you too.A great read Dan the lift looks to be a winner hope you get the starting problem worked out
have a Merry Christmas.
