IdahoMtnSpyder
Well-known member
How I wired up a 5 wire trailer harness on the bike, plus other lights. Part 1
I bought an after market hitch for my 2013 RT so a wiring harness was not included. Besides, I wanted to be able to connect my 5 wire trailer to the bike as a 5 wire trailer. IMO, it it imperative that you use an isolator to power the trailer lights, for two reasons. The Spyder cluster is finicky about added load to the turn signals as has been discussed by others in other threads. The isolator adds only a slight additional load and doesn't upset the cluster. But more importantly, the isolator will protect the cluster. If there is any kind of short or other problem in the trailer wiring you will blow bike fuses and risk screwing up the cluster if the trailer wiring is connected directly to the bike wiring.
Here's the harness I made up.
The Y harness is BRP part # 710003200. It's a called a module for some dumb reason.
The isolator is similar to this one: http://wingstuff.com/products/34253-electronically-isolated-trailer-wire-harness?from_search=1. I cut the connectors off and connected it to a Deutsch 6 pin connector DT04-6P. They're available from various eBay sellers.
The four wire and three wire connectors are AMP/TE Connectivity Superseal series 1.5 and are the same as used elsewhere on the Spyder.
The Wig Wag brake module is this one: http://www.signaldynamics.com/backoffwigwag
I wanted to add a high mount brake light and turn signals so I did those the same time I did the trailer harness. I connected into the wires in my harness rather than tap into the bike OEM harness. If all you need or want is the trailer harness then all you need is the isolator and the Deutsch connector. You have the option of cutting off the Deutsch connector from the Y harness and splicing the wires directly to the isolator input wires.
Here is the wiring diagram I made up. I've modified it some for this posting.
You will see an additional 12 volt + and ground connections on the diagram. I ran a separate 12 gauge wire from the battery back to the trailer connector to have a direct power feed to the trailer. I'm thinking of using my trailer for camping and carrying an auxiliary deep cycle battery to power a CPAP machine at night. Then I plan to feed bike power to it during the day to recharge it. I will have an isolator in the circuit. That's another project for later.
I mounted all this under the left side access panel under the seat. One of the Y harness connectors was still loose when I took the photo.
