how hot do your brakes get
gubby
hello all I have a 2012 rts with 10800 mi. on it numerous dealer issues which I will get into at a later date. Rear brake new pads, roter and caliber outside air temp. approx.70 degrees 5 mile ride moderate braking roter shows 216 degrees is this normal?
Interesting. ...
I have never measured the heat on the discs after a ryde. Are you having warpping issues or other problem..? I am interested in seeing if anyone else has a idea of the operating temp on the brakes...:thumbup:
yes which is why roter and caliber were replaced.
Gubby, You must be riding pretty gently for them to only reach that sort of temp!! If they get too hot or can't dissapate heat fast enough, you'll get what is commonly called 'brake fade', but these Spyders have pretty damn good brakes, & you'd hafta be ryding them pretty hard to do that, cos it's getting up close to 'melt metal & boil brake fluid' temps!! (& your brake fluid will boil at a whole lot higher temps than water!! :shocked: ) Warped rotors are rarely due to overheating them, but far more often due to 'incorrect cooling' from things like dunking them in a deep puddle when hot, or sitting with your brakes on hard for a few minutes after some spirited riding, or the disc/pads were just plain defective, which does happen every now & then! :dontknow:
Put into simple terms, your brakes work by converting your speed into heat via friction thru the pads & discs, which then dissapate that heat fairly rapidly so you can contine to use the brakes to slow & to stop safely. If you ryde 'spiritedly', at times the discs on 'production bikes' will actually get to the 'glowing red' stage, which IIRC is pushing close to 600 degrees C. On race bikes out on the track with their hi-tech pads etc, their brake temps can easily reach 1400 deg C plus!! So your brakes are fine if you are talking 216 deg C, but they are barely working hard at all if you are talking 216 F!! :rolleyes:
Still, if you feel the brakes aren't working properly, the very first thing you should do is go & get them checked!! Your brakes are just as important as your tires - between them, they keep you in contact with the ground & allow your Spyder to corner & stop safely, so you should NEVER take chances with either!!
More info here: http://cartechstuff.blogspot.com.au/2016/04/brake-temperatures.html
Put into simple terms, your brakes work by converting your speed into heat via friction thru the pads & discs, which then dissapate that heat fairly rapidly so you can contine to use the brakes to slow & to stop safely. If you ryde 'spiritedly', at times the discs on 'production bikes' will actually get to the 'glowing red' stage, which IIRC is pushing close to 600 degrees C. On race bikes with their hi-tech pad materials & on the track, their brake temps can easily reach 1400 deg C plus!! So your brakes are fine if you are talking 216 deg C, but they are barely working hard at all if you are talking 216 F!! :rolleyes:
thanks for your info
