help in lake George, limp mode
TOPDOGJIM
Our First Ride Today The Spyder started Flashing Limp Mode. We WereOn Rt 9 And Though It HasHills And TwistIes, I Was Not Riding The Brake.
The Light Keeps Coming On And OfF No Matter Were We Ride, Highway, BackRoad Etc.
Any Thoughts Or TowTo Dealer. I Also HavE No Idea Why My Phone Is TypingThis Way.
First, try to pull up any active fault codes by pressing MODE, SET, and the turn signal cancel simultaneously. The Alphnumeric codes may shed light on the reason. Second, try to shut off the Spyder, wait 30 seconds, and see if limp mode clears after rebooting. You may need a couple of tries. Lots of possibilites, not necessarily requiring a tow. With a little more information, we may get you back on the road.
First, try to pull up any active fault codes by pressing MODE, SET, and the turn signal cancel simultaneously. The Alphnumeric codes may shed light on the reason. Second, try to shut off the Spyder, wait 30 seconds, and see if limp mode clears after rebooting. You may need a couple of tries. Lots of possibilites, not necessarily requiring a tow. With a little more information, we may get you back on the road.[/QUOTE
P2416
code P2416 =*
Involved module = ECM
Description = O2 Sensor signals swapped
Cause = Wrong O2 sensor position after O2 replacement or wire replacement
Service Action = Swap O2 sensor wires
In short, check your 02 sensors.
Sent from my SCH-I605 using Tapatalk 2
code P2416 =*
Thanks I'm Off To A Dealer In Hudson Falls Ny In The Morning.
Just wondering if the "pulling code" process is super finicky? I've tried several times to check the codes on my '12 RT limited to verify the 'Brake Failure' :yikes: flashing on the screen and all I get is a blank white screen. Could it be there are no codes? :banghead: Thanks
That means the code is not active at the time you checked it. Your dealer can check past code occurrances with BUDS.
Thanks ForThE Info Guys.Just Returned From Progressive Motor Sports In Hudson Falls Ny.Incredible Service. They Replaced The O2 Sensor. I Had 10 Days Left On My Warranty. Who Is It That Sells The Extended Warrant At A Discount?
I purchased a BRP extended warranty from Vanessa at PitBull Powersport during Spyderfest at a great price. You can contact her at (417) 863-1418.
