Bam Bam and Pebbles
Got the heel-toe shifter from Value Accessories yesterday, and of course went right out to install it. Came upon a couple of problems. First, when I first put it on, the heel portion of the shifter was scraping against the inside panel. So I took a hammer to it to put enough of a bend in it so it would not scrape. Then when I tightened the bolts to the existing shifter, found that it went too far back, causing my leg to hit the passenger footboard. It also was set up too low for me to push my heel down far enough to shift. Part of that problem may have been that that is the foot that I had a toe amputated on and the issues with my foot could have been causing this problem.
So what I did to get it to work was drill new holes in the HT shifter, and corresponding holes in the existing shifter to get it lined up exactly where I wanted. I used a hacksaw to remove the extra shifter in the front. My foot doesnt hit the passenger floorboard and the heel shifter is high enough up so it works well with my old crappy ankle. I took it out for a short test ride and it works fine. I still have to paint it but my bad foot was killing me, and Pebbles was on me to rest it before I did any damage to it.
