Heat-sink paste
WaltH
Senior Member
The Spyder shop manual calls for heat-sink paste to be applied to new spark plugs. Some Spyder dealers seem to be ignoring this requirement and their parts departments don't stock the stuff.
Are you using heat-sink paste?
Dealers that do not use the paste are not following the Service Manual procedure, which calls for the application of P12 heat-sink paste (P/N 420897186).
-Scotty
Its supposed to help dissipate the heat from the sparkplug
-Scotty
Scotty: Do you use this - yourself?
There are a number of things in the maintenance schedule and shop manual that I choose not to do. I don't know if heat-paste will be one of them. It would be helpful to know what the consensus is in the Spyder community.
I have not had to change plugs in the Spyder yet, but I will use the paste. There is usually a good engineering reason for specifying things like this. Most stem from problems discovered during prototype testing. On some engines a heat-sink paste or anti-seize compund also keeps the plugs from seizing in the alloy heads. I will do whatever BRP requires as long as the Spyder remains under warranty, even if I think it is overkill.
-Scotty
-Scotty
Aren't most anti-sieze compounds high in metal content and are going to behave like a heat sink compound anyway?.......Is there any difference :dontknow:
Just trying to avoid having to buy the BRP stuff.
That would be my guess, but there are other considerations. A metallic compound can increase or even cause electrolysis. I think it is better to go with what the manufacturer uses, and has tested. Not sure of the cost of the BRP stuff, but one tube or jar should last you a lifetime.
-Scotty
What is the difference between heat sink and high temp anti-sieze paste. I have used anti-sieze for years in aluminium heads with no trouble. The BRP stuff must be expensive, I'm sure.
Use the heat sink paste. Your sparkplugs will love you for it. It will help your sparkplugs last longer. Its about dispersing the heat. A tube will last a life time. BRP thinks its important enough to make it part of the mandatory tools to be a dealer.
Your still not telling me why. Anti-sieze is hi heat grease (paste) and I would think the same product that BRP sells but is already in my garage. Plugs that are made of steel and are in aluminium heads need it to ward off corrosion I thought and I have used anti-sieze for as long as I can remember so what or how can BRP paste do anything different. Where can the heat be disapated to.
OK, tracked this stuff down.
:lecturef_smilie:
The heat sink paste is made by Wacker Chemie AG and is otherwise known as Wacker Silicone Heat Sink Paste P12
This same stuff is also specified for all Rotax aircraft engines.
It's also commonly used by Electronics manufactuers as a heat sink paste.
It's a pure silicone grease (polysiloxone) with suspended ceramic particles (most likely zinc oxide though they're not giving away that information). Thus it is chemically neutral and does not conduct electricity. It is used specifically to better transfer heat from the plug to the head by filling the gaps in the theads and providing a larger contact patch to conduct heat.
It is not the same as an anti-sieze compound, most of which are made of various metal compounds in a petroleum based grease. They are designed to allow the grease to vaporize and leave behind the lubricating metal compounds.
I guess I'm going to have to break down and order a tube from my dealer :sour: though Radio Shack's Heat Sink Grease is also pure silicone with Zink Oxide but who knows how the formulations might differ.......still in a pinch it would probably work.
All my years of changing plugs this is the first I've heard of using paste.Not that your going to change plugs to often on the Spyder I suspect but would there be any noticeable difference if not used?Snowmobiles have aluminum heads as well and BRP has never mentioned any procedure for them.:dontknow:
:lecturef_smilie:
If it does not conduct electricity, it would seem that it would interfere with the firing of the plugs???? Don't they get grounded through the base????
I've used the white heat sink paste, on actual heat sinks, for years in the electronics industry. Any of the silicone based, white pastes, should do the job.
Retired engineer - thought this stuff was behind me - never would have to think about it again.
