Cleg
:gaah:for some reason, lost power to the GPS after a new battery was installed. Checked all the obvious with the GPS thinking it was the issue...but it worked when directly hooked to charger:banghead::banghead: Checked with Garmin if there is an inline fuse, no there isn't :cus:..there is a 2 AMPer. That wasn't the issue it was the power plug for the heated rear grips, where the GPS plugs in, that had come unplugged. Frustrating because I didn't want to remove all the tupperware
pps: but an easy fix. :bowdown:back to basics worked.
