Gates Krikit II Belt Tension Gauges
BajaRon
Well-known member
These Krikit II gauges are very accurate and quite handy to have. I get a lot of requests for this gauge but I can't always get them for a good price. I recently got a good deal on them so I'm making them available for $18.00 shipped.
There is a great little video I've attached showing how this gauge works. This is the heavier gauge designed for the flat belts we run on our Spyders.
There is just one gauge labeled by different companies. The video is of a Dayco gauge but it's just a relabeled Gates gauge (which is the one I have).
I can ship these worldwide for a bit more.
Ron
Hopefully you have some tension #s filed away.
What should I aim for on my '08 GS with all 3 wheels on the ground? I recently replaced the belt due to a stone/something hard hole.
Thanks
og
Ron
Thanks
og
160-180 # for that belt.
All PM's/Emails have been replied to. Ordered gauges will be shipping out today. Thanks! :ohyea:
Thanks..!!
thanks for the video and making the belt tension guage available to us. :2thumbs: you have great stuff for the members here...:thumbup:
I've gotten some emails about international shipping costs for the Krikit II Gauge.
Shipping by USPS 1st Class Mail to;
Canada - $2.50
Everywhere else in the world - $3.95
Shipping by USPS Priority Mail to;
Canada - $19.00
Everywhere else in the world - $23.00
I've gotten a lot of inquiries about setting the proper belt tension with the Krikit II. This tool is simple, very easy to use and quite accurate when done correctly. But you need numbers!
Doing some research and crunching/converting the values (Newtons to Pound Force) this is what I came up with. The original Newton specs. came off of the Internet. You should check your owner's manual to verify my numbers.
Tension values for the 2013-2015 Spyder Belt are higher than for the 2008-2012 Spyders. I did not calculate 'Wheel on the Ground' figures for the 2013-2015 models as they will exceed the 330 lb. measuring limit on the Krikit II gauge. 2013-2015 Spyder owners will need to raise the rear wheel off the ground to get an accurate belt tension measurement with the Krikit II gauge.
998cc All Models (2008 - 2012)MinSpecMax
Newtons - Wheel Elevated300n450n600n
Pound Force - Wheel Elevated - Krikit II 67 lbs.101 lbs.135 lbs.
Pound Force - Wheel on the Ground - Krikit II130 lbs.160 lbs.190 lbs.
998cc All Models (2013-2015)MinSpecMax
Newtons - Wheel Elevated900n1050n1200n
Pound Force - Wheel Elevated - Krikit II202 lbs.236 lbs.270 lbs.
1330cc All Models (2014-2015)MinSpecMax
Min
Spec
Max
300n
450n
600n
67 lbs.
101 lbs.
135 lbs.
130 lbs.
160 lbs.
190 lbs.
Min
Spec
Max
900n
1050n
1200n
202 lbs.
236 lbs.
270 lbs.
Min
Spec
Max
900n
1050n
1200n
202 lbs.
236 lbs.
270 lbs.
Thanks for posting this conversion Ron. Long over and glad it's here. Maybe it should be posted in the "shop talk" board as well.
I am hoping that once a number of riders get these Krikit II gauges that they can confirm my numbers.
Ok Ron how did you do it? Went to use my old Krikit today to check my belt tension and it no longer goes 'krik' when I press down on it. So time to order a new one. Just can't understand how you jinxed from that distance:-)
Takes Years of practice!
But honestly, I've never seen one of these wear out. It is strange that yours no longer works.
I bought one from Napa and it never worked "clicked" no matter how hard I pressed. Called Gates and they would replace and warranty the part. But, by the time paid to ship it back it really wasnt worth the $10 bucks I would save so I just bought another one.
Got a new one and it works as advertised.
Very strange. I'd have thought that Gates would just have you go back to Napa and exchange the faulty one for a good one. Napa usually stands behind what they sell as well.
They would have but it would of cost me that much in gas to take it back to Napa or mail it back to Gates. I had no issues in getting a new one just wasnt worth the $10 dollars versus the time it would of taken to drive back to Napa or mail it back to Gates.
belt tension values
Thanks BajaRon, a most timely topic for me!! I am in the throes of my first tire change and belt tension adjustment on my new 2014 RT. Selling Dealer badly screwed up original belt adjustment, another dealer hammered an oem trailer hitch into place so tightly I had to use a scissors jack between rear tire and hitch, beating it with a deadblow hammer for 20 some minutes before trailer hitch finally came off. Belt tension was [160 on the Crickit] nowhere near the values on your chart and had lots of belt vibration starting at 71mph on oem speedo. Now I have some real numbers to aim for.
Thanks Andy
Thanks Andy
I've gotten several feedbacks from owners saying that the numbers I've posted are exactly right. They find that the range I've posted is exactly what they get on their properly adjusted belt. I hope this helps a lot of people as incorrect belt adjustment can cause issues.
Too tight will destroy bearings.
Too loose will give you vibration issues.
Hi Ron,
I notice that your readings are all taken with the wheel elevated.
Does this mean I must assume that no reading taken while the wheel is on the ground will be useful? :shocked:
