Gasoline
Run what you like. No one is watching. but...
The engine REQUIRES 91 or better. Just read the engine emissions tag on the frame under your seat (RT) or frunk (F3). Its very clear. This changed in 2013 when the compression ratio in the 998 was raised and for all 1330s. 2012 and older merely recommended the higher octane.
I can feel the difference running the low quality fuel when I get stuck with it. Some don't care. But is it really worth the dollar or two to not use the required fuel and substitute a lower quality alternative the bike has to work around?
The last few times we went riding, Linda on :ani29:, and me on Vulcan, I put 88 octane in both. My Vulcan calls for 87--and since I fill both at the same time, I compromised at 88--down two from the usual. Noticing no difference in either machine. Is 87 in our future?? I can save up to 20 cents a gallon over 90? :dontknow::dontknow::dontknow: Decisions, decisions, decisions. :roflblack::roflblack:
Food for thought: Have any of you who use 87* octane weighed the cost savings per gallon Vs the money you spend on octane boosters , Sea Foam etc?
Yeppers, actually you are spending more than just filling up with 91*. Why make life so complicated when you can easily make it simple.
:banghead:
​Jack
Very few has premium gas.
"very few" is not none.
Buy your gas at one of the stations that DOES have premium.....probably 91 octane.
Next best is 89 mid grade.
Are you saying that most all stations near you have only ONE grade of fuel ??
I've sent a LOT of time in Iowa out in the country and don't remember ever seeing that.
On the road i will try finding higher octane.
You won't have to try too hard.
Every major brand station these days carries at least two octane levels and most 3; some even 4 or 5.
Now......if you stop at a bar in an 1800's shed that just happens to still have ONE gas pump........:roflblack:
These machines will run fine on US 87 octane...now cross a border and this may not hold true. Use seafoam to counteract the ethenol every other tank full
Im curious on the Seafoam. How much do you put in? The whole bottle or adjusted per amount of gallons?
SeaFoam was originally created as a marine fuel stabilizer.
It will do NOTHING useful when used all the time.......except successfully clean out your wallet.
And the ethanol in fuel does not need to be "counteracted".
USE THE GASOLINE THAT BRP RECOMMENDS.
A dose of a GOOD injector cleaner a couple of times a year is a good idea.......but SeaFoam isn't good for that either.
Just throwing this up for what it's worth to those who may be interested... We use RON rather than Octane here in Aus, so with that in mind - we can usually get 87 or 'standard ULP' for about $1-$1.20 per litre, 95 or 'Premium' for up to 20cpl more, & 98 or 'Ultimate' for another 10-20 cpl (or similar alternate labels for the RON levels depending upon the outlet/brand) at most servos on major roads here.
So, I try to run on 95 RON fuel, particularly since the manual here states something along the lines of 'use Premium or better fuel' - but I consistently get better than 4-5km per litre extra milage from 95/Premium than I get from 87/ULP, which pretty much means I get almost 100km greater range from a 20 odd litre tank of Premium than I get from a tank full of std ULP! (Range is quite important to me, especially since I have & prefer the 998 motor/smaller tank!) Besides, my Spyder clearly likes running on the Premium better & it lets me know in no uncertain terms that it's Not Happy Jan if I hafta feed it 87!! Not sure if that's due to the (relatively minor) air intake, exhaust, & tuning mods my Spyder is running, but it IS very uncomfortably obvious that my RT DOES NOT run as well on 87 as it does on 95 or better, altho there's no significant extra improvement in anything I can determine by stepping up to Ultimate over the Premium! Regardless, it doesn't take a mathematical genius to work out that even if I end up paying an extra 20c per litre for Premium over ULP, I'm still better off in the long run by running the Premium than I am running the 87 RON ULP stuff - I'm just glad that we don't yet have to contend with major Ethanol additive issues.... yet!
Over to you! :thumbup:
Why do Spyder people worry so much about Piss Ants while the Elephants are running over them? Unlike a Jet Engine which will run on anything
including cooking grease the Spyder will run on almost anything labeled Gasoline. Of course a little common sense and reading the Manual (carefully)
will help a lot.
There are so many opinions out there and it seams the overly strong opinions which some times is pure B-ll S--t leads the Poor Newby astray and
sometimes scares the hell out of him. My advice is read your manual carefully and take what it says to the Bank. Almost every question on this Forum
can be answered in the Manual. When you ask some of these questions the strong opinions and more forceful personalities take over with opposite view
points and confuse the new people and plant seeds of doubt.
This is not directed at anyone in particular nor specifically this thread. Just a little nugget of suggestion for the new and inexperienced.
Jack
Spreadsheets
I'm running a test of ten tanks of mid grade and ten of premium to figure my fuel cost per mile. I'm applying the actual cost for each at the pump and am halfway through the premium run. Yes, the premium costs more but my mileage is up enough that the cost per mile is the same. Now that's at the current $0.25 - $0.30 price difference. I'm sure that sometime in the future when the difference becomes bigger then this will no longer be true.
The ethanol isn't gonna hurt anything unless you let the bike sit for several months. Then, it might start to work on some of the delicate fuel components...if there even are anymore delicate components these days. Why make it so complicated? If you're truly concerned, do as Jack stated and read the manual and do what it says. Is ethanol bad??? only if left sitting for months. Is ethanol good??? well, it isn't hurting anything when used properly. I was recently in IA where their 87 octane fuel can be purchased labeled as "ethanol free"... So the octane level is still 87, but the fuel was labeled as "premium"...somewhat confusing, but if it states "ethanol free" then that tells me that it's pure gasoline. Then why is it not 91 octane? Hmmm.. Personally, I run 91 octane premium, ethanol free, when available. I've run many gallons of 87 with ethanol too, sometimes in the same day or weekend. Did I stress about it during my riding???? Heck no!!! Just fill it and ride it, and stop worrying. If you have a time of storage in your climate, fill it up with ethanol-free fuel, maybe add a bit of fuel stabilizer to the last tank, and wait for the warm weather to return
I have been using 87 - in my 1330 for 3 + years, IMHO it runs fine ....as has been mentioned the Spyder has Knock sensors to prevent damage ..... .01% loss of power is not worth the .60 it costs to use 91 .... Mike :thumbup:[/QUOTE
Mike, I've got a 2014 RT Limited and have used 87 Octane from day one and NOT ONE PROBLEM!!! Several of my Spyder friends in our club are very adamant about finding a station with 91 Octane when we ride.
AND I don't have any loss of performance.. All of the stuff about having to use higher octane is "fake news"! I guess the liberals started this... :yes:
BIG F
