Fuel Gauge Question
THE NOZZLE THING
My fuel gauge is not real accurate either, I was down 3 bars it took .8 of a gallon rode about 20 miles after the "fill up." The next time I got on it to ride it was down 3 bars again! I will stop dropping the nozzle all the way in to the tank and see what happens.:yikes: BTW, my Spyder is a 2013 ST-S.
..........If the nozzle is all the way in ...that's about 2 1/2 gal. of fuel.....I have the 2014 frame so the gas can't possibly get to the charcoal canister , so I fill to the top. Unless I am very close to home...Mike :thumbup:
Does the white LCD bar change color, once the fuel light is on, to let you know how much of the 1.5 or 1 gallons are left? I stop once my fuel light comes on. I was running hard at 85 mph tonight, and light came on at 148 miles, I finally came to a station around 167 miles
Fyi mine does not. Just the idiot light on dash,but that lights up on last peg on guage. The GPS if set up right will have been lit. Per the manual you should get 15-20miles on that last bit of reserve. (The gallon that does not show on gauge. Then the inevetable auidable alarm (engine dies, no sputter, just dies)best to keep eye on gauge & trip meters. Watch the heavy hand.
Do you put the fuel nozzle all the way in when filling up? If you do you will never get it full. I stick the fuel pump nozzle about an inch through the filler hole in the tank, that is it! When I first bought my :spyder2: I put the nozzle all the way in and when I started the :spyder2: to leave I was a bar down before I went anywhere.
This is one of the tougher bikes to fuel that I have owned.
Well guys if you think a Spyder is hard to fuel up, you have never own a Victory Vision, now thats a bike hard to gas up!
Ride safe!
So very true. As a former Victory Vision owner I am well familiar with the burping maneuver necessary to get a really full tank. While the low slung bifurcated gas tank helped keep a low center of gravity on the Vision, I have not had much success with burping the Spyder!
SpyderWalter
Just curious, did anyone ever get this issue with incorrect reading of digital fuel gauge sorted out. My 2013 RT fuel gauge has been driving me nuts. Despite filling it to the very brim, the gauge only displays 4 bars. Today, I went for a long ride and the fuel light came on at only 120 kms (72 miles) I then drove for another 30 or so kms and when I filled up I still had half a tank. This gauge issue has occurred before, and mysteriously fixed itself. But, no matter what I do now, it just wont work properly. I was wondering if I pulled a fuse to the instrument cluster and then reset it if that might do anything.
Nope! Particularly for the V-Twins, this is an on-going issue! My gauge & fuel light are still erratically and MASSIVELY incorrect! :banghead:
Sometimes it'll read perfectly accurately; sometimes it's only a little off; sometimes it's WAAAAYYYY off and very quickly at that!! :shocked: So far, the quickest it's shown the tank going from 'over-full' to 'absobloodylutely bone dry' has been about 800 yards, and the ONLY things I haven't done to correct this issue is to fit a completly new tank & to buy a new Spyder! :yikes:
Duzzn'matta what I've done - pulled the fuse; switched back & forth between analogue gauge & the digital gauge... repeatedly; removed & replaced the Magic Mirror Mounts.... also repeatedly; had the wiring checked for continuity and resistance... more than once; had the sender and the dash/gauge checked for continuity & resistance.... more than once; cleaned the tank (only in situ tho - it's a right pain to get out! :helpsmilie: ); replaced the sender with a 'known working' sender unit (altho admittedly, it was only bench checked in a bucket!); even had a new dash module fitted! :p
It seems that there's actually something going on IN the tank that causes the sender to stick at odd times &/or in odd places, or to sink at odd times &/or to odd levels... and there's no apparent rhyme or reason to when it choses to do which or what?! :gaah:
The dash module that came out bench-tested as being perfect (so at least I've got a spare now! :rolleyes: ) and the sender unit that came out also bench-tested perfectly ( yup, 'nuther spare! :rolleyes: ) and yet the fuel gauges, both the digital AND the analogue, are at best a potentially wildly inaccurate indication of what fuel you might have in the tank, or they might be very accurate - only you hafta guess when it's doing what! :yikes:
Just re-set a Trip Meter whenever you re-fill the tank, learn about how far you can go to still have some gas left in the tank, even if it's just a quart or so; and if you're travelling a long distance between gas stations, carry some spare fuel and top up EARLY, before you actually run outta gas!! Modern fuel injection systems REALLY DON'T LIKE BEING RUN DRY!! :lecturef_smilie: Do you hafta ask me how I learnt that? :p
Peter, thank you so much for long and detailed reply. You saved me from a weekend of wasting my time trying to diagnose the fuel gauge issue. I hate it when things are not working properly, but I guess I will learn to live with it. Motorcyclists have been riding without fuel gauges for years, so I will stick to using odometer readings. I wonder why this is an issue with the 998 cc? Did BRP change our the sending unit on the 1330 CC motor? Again, thank you. Love this forum.
