I understand that the front sprocket is to be checked at 6000 miles. Does that mean to remove the belt, , remove the sprocket, inspect the splines, then reinstall and torque ?
If so, then should there be any type of lubricant applied to the splines and is the correct torque 81 ft.lbs ?
I would like to do this myself so any advice would be appreciated
Thanks.
Thanks.
