jcthorne
Well-known member
Loosening the lower part of the airbox to move it is not the problem.... that's no big deal. That's what I did the last time and I still had problems. It's trying to work around it to get to the front plug. Why oh why did they make it impossible to remove the lower part of the airbox out of the engine cavity as it is on the GS/RS?? I can do a tune up on the GS in about a hour or less.... doing it on the RT is like having a second full time job. :banghead:
Then just remove the air box, change the plugs and put it back in. Its not THAT big a deal to remove. The right hand brace needs to be moved out of the way, along with all the stuff mounted to it. Once done and the bolts are off, the box comes out in one piece easy enough. I was just suggesting you not put it back in. Removing it still gets you access to the plugs.
