PMK
Obviously I didn't make myself clear. What I'm saying is you can use an mp3 player plugged into the 3.5, OR if you want to play from a USB stick you can use a BT transmitter to transmit the mp3 files off off the stick to the bike BT, if such a transmitter exists. I didn't intend to indicate you need to use an mp3 player and a USB stick at the same time. And I didn't make clear I do use a BT receiver for my tablet. It's some oddball brand I bought off eBay.
The upshot is, as I understand it, that with the 2018 Connect system you are not able to play mp3 files directly off a USB stick like you could with the earlier model years.
The Spyder, for all years being essentially Apple based, this made the IPod, or IPhone an easier hookup. Can Am left the 3.5mm jack simply to let other devices work.
Like you, not sure that a small device exists that reads a USB stick music file and can read and play the data, then transmit. Kind of seems redundent as a MP3 player or IPod with BT has that capability. Storing music on a stick is more for PCs.
Hope you figuire it out.
