Easy Rider
Me too.I am surprised you're having trouble. 30 degrees isn't all that cold.
It might mean that your battery is weak, meaning it isn't taking a full charge.
BUT....what exactly are you doing to start it ?
You should NOT open the throttle at all.
You should let it crank for 5 to 10 seconds before pausing.
If it sounds like the engine is turning over really slow, you definitely should have the battery tested.
The dealer could have neglected your battery for up to a year before you bought it.
You don't have any additives in the gas, do you ??
I know some people will find this "blasphemy" but regular grade gas might start better than premium in the cold.
Edit: Now that I have read ALL of the posts.................
The starter cranks over, then it cuts out. It does this over and over and over,
Definitely a case of: "loose" connection on one of the battery cables OR bad battery.
You don't have any extra electrical accessories that come on BEFORE the engine starts, do you ??
P.S. The battery is NOT a warranty item......unless you have a really good dealer.
