FOBO TPMS Custom images
By the way. All these images I made long ago were scaled and sized to the same size as the STOCK FOBO images they used at the time (I ripped them from the .ipa file). So they broke the software.
Bob
Last thing... Can someone on Android tell me if this same problem exists? Per my above post about pinching to fit in the box?
Thanks,
Bob
fobo
Yea but if you look close, the image looks pudgy... e.g. length is reduced more than width.
Bob
i got mine to work. I ran the image thru Corel photo , saved background as square and no issues . Worked perfect , I also cleaned up a line that appeared on the edge .
Thanks Bob and others for all the pointers
:spyder2::spyder2:
Thanks,
Bob
It's a little different and specific on Android. It took me a bit to figure it out. You have to drag the cropping box itself to one of the bottom corners of the image FIRST and hold it, then grab the opposite top corner of the cropping box and stretch the "cropping box" to the max to outline the entire image but I was able to finally get it done and it looks fine. :banghead:
Cool thanks! That is the way it USE to work with Apple. Not anymore.
So if I change the images for Apple to square, now they may not work right on Android. :(
I have not heard back from FOBO yet about the Apple problem....
Bob
Bob
Well, I'll keep a copy of the originals that I can send anyone with an Android if you end up having to modify them for Apple users..... :doorag:
