Fitting Replacement Gauges
DR Buck
Some of you have replaced the stock fuel and temp gauges with others. What I want to know is how well do the aftermarket 52mm gauges fit into the openings for the stock gauges? I believe the stock gauges are 2 1/4", or about 50mm. Do you need to add any filler pieces or oversized bezel rings?
My 52mm voltmeter fit fine. Though I did have to make some adjustments to the mounting bracket, which I found was too deep.
