vtrider
I had a busy weekend adding farkles to My RT this weekend. I installed the Sena SM10 dongle and homemade harness that I mentioned in another post and added a Firstgear panel mount DC connector to the switch cluster where the connector for the entertainment harness would normally go. I don't plan to add the entertainment harness, so this was a good place to add the DC connector. I can tell you though! This was not an easy install, getting the glove box off to get access to the underside of the switch panel in order to add the connector. I did manage though and it looks real good. I ran the wire harness for this to the battery with on inline fuse connection to the +12V. I will be using this connector mainly for my heated jacket and gloves. It will also make a good external source to plug in a battery tender. This is the connector that I ordered from the Motorcycle Super Store. http://www.motorcycle-superstore.com/46071/i/firstgear-6-dc-coax-panel-mount-connector .
