trikermutha
I never done one but it its on the right side of the engine in front to the oil filter.
Manual says to that the water pump gear may stay in the engine and you will need to remove it from the engine.
Pull out needle pin and withdraw thrust washers with axial needle bearing from water pump shaft.
Check bleeding nozzle in cylinder head if it is clogged. Clean if necessary.
Looks like there are 5 screws holding the water pump.
Water Pump Module Installation
The installation is the opposite of the removal procedure. However, pay attention to the following.
Before installation lubricate: – Water pump shaft – Washers – Axial needle bearing – O-ring.
WATER PUMP PARTS LUBRICATION Service product Engine oil
I didnt copy every detail in the manual but you get the idea.
Water pump screws are 9 ft lbs torque
Thermostat Test Water pump module installed in vehicle Start engine and let engine heat up to operating temperature (higher than 80°C (176°F)). Check if the main supply hose from radiator to water pump module heats up with engine at operating temperature.
