With the frame reinforcement completed, I ordered the beefier rear shock yesterday. Will install it myself...should be a two-beer job. :cheers:
JB
Installed mine yesterday, and it was easy, but (as always) a bit of learning curve the first time..I could do the second one in half the time) :f_spider: The test ride was surprising, in that the ride is much less-harsh; the rear end doesn't sag as before when I mount up; and the ride on the local bumpy roads was MUCH smoother!
Some might suggest that it's just the old thing about the bike running better after an oil change, but I honestly feel the difference in my butt and back...no bottoming out and much smoother...the best $180 I've spent on "Buster".
I'll try to post a link with photos and instructions, but here's a starter:
1. Chock both front wheels so the spyder doesn't move when the rear is jacked up.
2. Place a small hydraulic jack of your choice under the rear of the box frame (just forward of the primary muffler), and lift until the rear tire is barely off the ground...then lower it until the rear tire barely touches the ground (this will be about the right position to take the load off the shock and yet keep the shock bolts from being under tension when removing them).
3. Remove the rear seat only.
4. (if you have BRP side cases, remove both of them)
5. Get a 15mm box wrench and socket with extension(s) for the shock bolts.
6. Pay attention to the orientation of the bolt head...they are different from top to bottom...the bolt head at the top of the shock is on the left side, and on the bottom it's on the right side.
7. Remove the plastic splash pan under the seats. There are 2 torx screws on top under the rear seat, and 15 underneath (12 of which are in the 4 panels you'll see readily. I'll send photos of the two on top under the seat, as there are a bunch, and you only remove two...the CORRECT 2 :f_spider:
8. Remove the original shock and put it aside.
9. Install the new shock..you may need to make slight adjustments to the jack height in order to slip in the lower bolt so as to NOT bugger up the threads on the bolt. When you get it lined up correctly, the bolt will slip into place without forcing it.
10. Reinstall the plastic splash pan.
11. Reinstall the rear seat.
12. GO FOR A TEST RIDE AND ENJOY THE FRUITS OF YOUR LABOR!
Cheers JB
