Someone humor me please that has a set.
OK....
1) Pull the bag off the Spyder.
2) Now on a table, turn the dial till it stops. (At that point you should be fully extended into the locking position)
3) Try to push it backwards from the outside. (In theory you should it will not move)
4) Now, manually attempt to push the arm forward from the outside (eg. No dial), even if its minor.
Question. If you WERE able to move it manually forward from the outside, can you now push the
arm backwards? (Did it unlock)
What I discovered on both. If you use the dial alone to lock the bag, the arm will stay locked. If for
some reason you scoot the arm forward manually it will unlock. (So the dial only goes so-far with the
arm BUT, if you were looking from the outside, and attempt to move forward, mine will unlock). When
setting-up I manually moved the arm forward to be in the forward-most possible position into the
stopping block... that actually is about 1/8" at the most further than the dial itself can do. (Thus my
problem)
That being said, if I re-adjust my stopper block backwards to EXACTLY match the forward motion made
by the dial (thru the arm) it will/should stay locked. Anything else forward it will not.
OK....
problem)
