Dutchy
As you all can probably gather, I have the above light from BRP now half of the strip is not working and unrepairable, so I have now picked up the Rocket Bright Light to replace it, the question I have am I able to use the wires from the old signature light, (remember it has a relay) so I am looking at cutting the wires after the relay then attaching the new light using the old wiring including the relay.
Even though the gut is saying it will work I am not that sure on what the relay does and will if stuff up the light, the questions I have are:
1. will it work;
2. would it be best to use the customer accessories connection; or
3. just try it and see?
If it works, it'll be one easy install
As I was typing, I found the answer customer accessories apparently as the relay is part the problem
1. will it work;
