F3unlimited, while there is no way to specifically adjust the camber, if you've got adjustable height shocks or adjustable pre-load on your shocks, it
might be that which is upsetting things. Winding either of those adjusters up
too much can raise the Spyder/Ryker suspension enough to cause excessive positive camber, which will make your steering fairly direct on an absolutely smooth flat road in a straight line, but it'll usually be really twitchy & uncomfortable on anything but that absolutely smooth flat road!!
So if the shock height/pre-load adjustment has anything to do with your problems F3un, you'd hafta have the Right hand shock adjusted so that it's too high/got too much pre-load;
and the Left hand shock adjusted so it's too low/got too little pre-load...
DO you have any adjusters on the front shocks??
There again, maybe you should just check how much weight/load you're carrying in/on the left hand side of the Spyder - too much weight on that side might just settle that side front down enough to cause your lopsided camber by lowering the Left side of the F3 & in turn, raising the Right a touch... or it could be that you've got a worn or loose bush or two on the anti-sway bar or some other suspension components (inboard end of the 'A' arms maybe?); or maybe you've got a bent suspension arm or anti-sway bar??
There's quite a few things like that which
MIGHT be causing or at least contributing to your F3's lopsidedness...
Still, it
IS a new machine & I'd hope it's still under warranty, so really, it's something that your dealer &/or BRP should address. I just hope it doesn't get dragged out interminably and turn into a prolonged saga of you/your Spyder/it's problems being ignored by both of those parties in the way so many of these things seem to end up! It seems to be becoming an identifyable trait of the brand! :yikes:
Good Luck!
