F3 Limited radio issues
tango i was wondering if you had a chance to try that out on musha
MUSHU is at the SPA(dealer) again for the shock adjuster issue. They are removing the shocks to free them up, and reinstalling them. They are also trying a different antenna. I will call them tomorrow to try turning off the LED Fog Lights. Don't know how to turn off head lights. Maybe pull the fuse? :dontknow: Tom :spyder:
I've had the radio issue with my F3 L since day one. Well before adding Lamont's fog lights.
Rick
That's not what I wanted to hear. :yikes: I guess the signal blockers Lamont found may not work. :dontknow: Tom :spyder:
I think there is a radio issue and maybe the ones that are on the edge the LED's push them over the edge. We'll get it figured out. :doorag:
My RT is going in the shop tomorrow for a splash of fresh oil. I'm going to have the technician pull the antenna, clean off the Loc-Tite residue, and re-install it as per Billybovine's instructions. :thumbup:
Dealer is ordering a longer antenna for MUSHU. We all know it won't do any good. But, he has to follow BRP's orders. He doesn't know of any solution to the problem. And BRP is clueless at this point. :banghead: Tom :spyder:
dealer
my 16 f3 limited special is at shop today getting first service and oil leak fixed when i dropped it off yesterday the told me brp had got back with them told to check ground on antenna i ask them to put short one back on as it did not help hope lamont comes up with fix for fog lights
Mushu is at the dealer again for the radio not working. I saw the antenna that BRP sent. It is at least double the length of the stock one. As far as the LED fog lights. Made no difference off or on with mine. :banghead: How a multi million dollar company can't figure this out boggles the mind. :roflblack: Tom :spyder:
The new longer antenna is better. Reception kept coming and going, fading in and out. But better than the shorty. Still no AM, or NOAA at all! Now waiting to see what BRP does next. Rusty has had it three times now for several days. :banghead: Tom :spyder:
Mushu is at the dealer again for the radio not working. How a multi million dollar company can't figure this out boggles the mind. :roflblack: Tom :spyder:
This radio issue on the F3L is NOT the first unsolved issue within the Spyder line up for BRP, that "boggles the mind". That dealers are clueless about issues, brings into question BRP's communicaton network. Turning the customer into a field tester for the supposed fix for no compensation is wrong on many levels. Does a multimillion dollar company not have R&D and QA/CQI departments that test manufacturer produced and supplier produced parts??????
Now that Lamont is "ON" this radio issue, the possibility of a correct solution has increased signifigantly. Good Luck to all radio equipped F3 owners.
Mike
It will be OK
Mike
Try not to let it ruin your day! It's only a radio!:roflblack::roflblack:
If it's "only" a radio. Why did they charge us for it? Should it have been free? :banghead: Refund everyone's money that paid for the radio. A $1000 would do. :thumbup: Tom :spyder:
What was the problem for the oil leak?
Thanks
