Exhaust noise?
Tilty
I have a ticking noise coming from the right hand side. I asked a friend he said it sounds like an exhaust leaks from one of the joints. I took off all the panels and tightened the clamp about 3-4 turns it got a little better but can still hear it. Anyone had this problem? I'm going to order the the exhaust bushings and see if that helps. Only have 6600 miles the book says they should be replaced at 12000 ?
Most likely your right hand slip-joint gasket is burned up. They are usually referred to as Y gaskets on here, and the BRP ones are known to fail fairly early on. If you only have 6600 miles, BRP may cover the replacement under warranty. However, what many of us have done is to switch over to a Honda gasket that is much better quality than the stock BRP ones.
Here is a link to a How-To thread with all of the information you will need to do it yourself, if you decide to go the Honda route:
http://www.spyderlovers.com/forums/showthread.php?t=19691
